Latest: sparrowdclxvi
Overall: 17139
Online Now [170]:
Visitors: 169
Today: 15365
Total: 113215491
Forums › The Car › Solved 206 Problems › speedo binical
speedo binical
tinks
PostPosted: Fri Feb 22, 2013 12:47 pm Up
Hi new on here,I have owned a 206 gti sp for a few years now the speedo has packed up i wish to replace this. I have noticed on e bay some have one plug others two could anyone tell me which one i would need its a 1999 v plate
PostPosted: Fri Feb 22, 2013 2:20 pm Up
You need a NON plexed / 2 plug instrument cluster.
You really need to check the speed sensor input to the BSI unit first as non plexed 206's electrics are pretty poor.
tinks
PostPosted: Fri Feb 22, 2013 4:10 pm Up
thanks for info had garage check sensor in gearbox read this can be a problem,but told this was working ok told it was the cluster.whilst here would you knowif the milage can be retained (60 000) or would it read new s/hand milage.cheers.
PostPosted: Sat Feb 23, 2013 6:45 am Up
On a non plexed 206 like yours they display whatever the mileage is that is stored inside the cluster memory.
There is a part you can swop over to the replacement cluster to retain your original mileage BUT as I don't work on non plexed 206's I've no info on how to do it.
The info should be on the forum, I remember it being posted up in 2012.
