Online Now [657]:
Visitors: 657
Today: 32948
Total: 146931504
Forums › The Car › Solved 206 Problems › rear wiper problem
rear wiper problem
Forum Index › Solved 206 Problems
ffox
PostPosted: Sat Feb 23, 2013 10:58 am Up
I've recently bought a 04 plate 206 hdi gti.The rear wiper will only activate when i select reverse gear.Any suggettions as to what the problem might be will be greatly appreciated.
Tolkienfan001
PostPosted: Sat Feb 23, 2013 12:35 pm Up
Trade Rating: +13
Comms unit. Mine had the same issue. Bought a new unit from ECP. Problem solved.
2005 1.4 16v Sport
Check out my 206 here!
PostPosted: Sat Feb 23, 2013 2:01 pm Up
do u mean that when your front wipers working,and you select reverse it works?? if that is the case,then it's normal,but if it's not working when you turn the switch,then as said above,you need a new com2000
Tolkienfan001
PostPosted: Sat Feb 23, 2013 2:49 pm Up
Trade Rating: +13
Yea mine did exactly that. Would not work on the switch, but when I had the front wipers on and reversed the wiper worked.
2005 1.4 16v Sport
ffox
PostPosted: Sat Feb 23, 2013 3:44 pm Up
Thanks for the assistance.Can anyone please give me a link for the unit that is required.
Tolkienfan001
PostPosted: Sat Feb 23, 2013 3:51 pm Up
Trade Rating: +13
www.carparts4less.co.uk/
Remember to use the discount code on the front page.
Also put your reg in and buy the one that matches all your current functions.
Finally, when fitting use the battery / BSI shutdown procedure and the guide if needed.
www.206info.co.uk/Foru...ttery.html
www.206info.co.uk/Foru...comms.html
2005 1.4 16v Sport
