Latest: Beduff1977
Overall: 17134
Online Now [592]:
Visitors: 591
Today: 125435
Total: 109120244
Forums › The Car › 206 Talk › Can I relocate the CAT???
PostPosted: Sat Mar 02, 2013 1:25 pm Up
Hello guys,
As title says,I wanna ask if I can relocate my car (1.4 8V) CAT,as you know it's located in front of the engine,so i'm thinking of changing it with a new one,but I want to know if change it's location would affect the car,and would there be EML light on because of the O2 sensor or not??
I'm thinking of fixing the new one under the engine.
PostPosted: Sat Mar 02, 2013 1:26 pm Up
As long as you extended the downstream sensor (lower one) to after the CAT, no problems will occur
PostPosted: Sat Mar 02, 2013 1:27 pm Up
Why?
Its a lot of hassle for no gain.
PostPosted: Sat Mar 02, 2013 1:43 pm Up
The 1.4 8V have only one O2 sensor,and upper one,but there is a plug for a lower one ready for use.
PostPosted: Sat Mar 02, 2013 1:47 pm Up
Mines got 2 O2 sensors Wink
PostPosted: Sat Mar 02, 2013 1:48 pm Up
MrBSI wrote:
Why?
I don't wanna gain anything from this as a power or other stuff like may other think of,but the reason of this question is that,my car done 100,000 Kilo meter on the clock,and I have recently start to smell like a rotten egg ,so I can't find a brand new one to fit ,so thinking of fitting a universal CAT,and locate it under the engine like other models
PostPosted: Sat Mar 02, 2013 1:51 pm Up
The cat should last a lot longer then that, that works out to just under 62.2k miles Shocked
PostPosted: Sat Mar 02, 2013 2:04 pm Up
I think the reason it might be faulty,that the engine sound is rough running,like a tractor,and air flow is not as good as it should be,and how come you have 2 sensors,and I have only one ;),did you fitted it yourself :D?
PostPosted: Sat Mar 02, 2013 2:11 pm Up
If its placed under the engine, wont it be close to the floor?
PostPosted: Sat Mar 02, 2013 2:17 pm Up
It left the factory like that, downpipe cat with pre & post cat lambda sensors.
PostPosted: Sat Mar 02, 2013 2:22 pm Up
not exactly under the engine,just behind it,close to the gearbox links
PostPosted: Sat Mar 02, 2013 2:24 pm Up
Would love to see a pic of that please,can you do it?
PostPosted: Sat Mar 02, 2013 2:27 pm Up
You cant really see the post cat sensor unless you get the car up on a ramp.
The pre cat sensor is just screwed in to exhaust manifold, then cat in the downpipe then another lambda sensor after the cat.
All the 2nd sensor basically does is check the cat is actually working correctly.
PostPosted: Sat Mar 02, 2013 2:45 pm Up
Well that is my CAT,but i have no 2nd O2 sensor like the one in the diagram,have you used your car VIN on service box or some other car,what I meant is to see how is your CAT is located Very Happy
PostPosted: Sat Mar 02, 2013 2:51 pm Up
I used my VIN number, my TU3 206 is L4 VEHICLE TECHNICAL DEPOLLUTION according to Service Box.
