Online Now [300]:
Visitors: 299
Today: 78209
Total: 106272369
Forums › The Car › 206 Problems › cracking up need some advice
Mikenulster
PostPosted: Thu Feb 21, 2013 10:54 am Up
right so the car has had new cat down pipe, changed coil pack changed ngk plugs to bosch got brawn new lambda sensor and car running much better but its still lumpy when im on forth gear and exhaust pipe tail shaky so what the hell else could this be ? oh and when i took 3rd plug out it was sorta wet and clean the rest where dry n nice brown cheers for helping
andrewkeen
PostPosted: Thu Feb 21, 2013 1:04 pm Up
Sounds like the problem I had with my Mrs's car. It was a bent valve, would explain the wet plug. or one of the plug thats wet isnt sparking? Have to tried taking the pack out and inserting the plugs and turning the car over with the plugs near a metal source to see if their all working?
Andrew
Mikenulster
PostPosted: Thu Feb 21, 2013 1:34 pm Up
yea thats what i was thinking andrew think i read thread with you saying that problem before.. i hope it isnt but i cant think of anything else i was gona get injector cleaner tomorrow n see how it goes. n yea all plugs with the coil pack are sparking.
PostPosted: Fri Feb 22, 2013 1:50 pm Up
Leaking injector on No3?
Mikenulster
PostPosted: Fri Feb 22, 2013 3:21 pm Up
how will i know for sure? will i see any petrol at all? i checked all round the rail n cleaned it no sign of anything and used injector cleaner. i also listened to it when on and could here them work fine but def something thats wrong. im hoping by the 3rd plug being clean again its not piston rings valve stem or head gasket etc my car is spot on no engine light better fuel milage and back to power again its just slight misfire and in 4th 5th shakes like hell fs Sad
PostPosted: Sat Feb 23, 2013 2:59 am Up
First get a compression test done - just to be certain it isn't head gasket or valve problem.
I don't mean an external injector leak but an internal one into the cylinder - injectors don't always reseat properly and then they leak. The extra fuel will cause a misfire and wet plug. Though it ought to bring up an engine light.
If the compression test shows the engine in good condition and all cylinders within 10% of each other you could swap No3 injector with No4 and see if the fault follows the injector. If it does it is injector problem. If it doesn't then you have another fault.
It may also be worth reading the codes, clearing any stored, driving the car and then reading them again.
I also note you have had exhaust work done. A leak on the exhaust can cause strange problems. Get someone to hold a rag over the end of the exhaust while you check for leaks. If you have a leak fix that before anything else.
Mikenulster
PostPosted: Sat Feb 23, 2013 10:56 am Up
ah right i see.. i will get that checked asap.. the car is running much better again the more i use it which is good but still there and i done that with the exhaust and found a tiny tiny hole befpre the back box this wouldnt cause anything would it ? to misfire ? thanks for the help mate
PostPosted: Sat Feb 23, 2013 11:03 am Up
Leak just before the back box is unlikely to cause a problem. A leak before any sensor, as you know from recent experience, will.
You can buy a compression tester from any good motor shop (just make sure it has the right screw thread (same as your plugs) for your head or a garage will do one for relatively little money.
Swapping injectors is free, except for your time and provided you don't damage anything doing it.
Mikenulster
PostPosted: Thu Feb 28, 2013 8:25 am Up
update .. just had diagnostic test in a garage and they have said its the coilpack and i need new set of plugs but ive went through three sets of plugs and tried two differant coil packs but same problem. it seems to run better again when warm but when i start it shakes badly again and engine light on untill its warm. im left clueless
LORDPSK
PostPosted: Thu Feb 28, 2013 10:17 am Up
did you do a compression test as suggested in previous post
Peugeot 206
PostPosted: Sun Mar 03, 2013 8:44 am Up
Is No3 plug still oily? As before compression test (have you had it done? What were the readings?) and swap injectors No3 for No4 and see if the fault follows the injector.
PostPosted: Sun Mar 03, 2013 10:21 am Up
What was the actual codes? Rather than stabbing in the dark...
Mikenulster
PostPosted: Mon Mar 04, 2013 6:55 am Up
yea going to swap injector 3 for 4 today see what happens n havnt got it done yet mate havnt had time to buy one.. but im hoping its the injector now. didnt get to see the codes addaz raging typical garage thats just fitters they gave me receipt not codes.
Mikenulster
PostPosted: Tue Mar 05, 2013 12:13 pm Up
so swapped injectors 3 to 4 and injector 3 wwas clogged with crap.. cleaned it put it in and comes out it followed to cylinder 4 the plug was wet so happy to say its the injector Smile thanks for the help people!
