Online Now [514]:
Visitors: 513
Today: 10929
Total: 106205160
Forums › The Car › 206 Talk › Rear Bushes
Rear Bushes
PostPosted: Mon Mar 04, 2013 6:42 am Up
Apparently on the rear beam of my 180 there are 2 struts, 1 either side with bushes on top of them, my bushes have split so need replacing but have no idea which bushes I need to get myself, any ideas?
PostPosted: Mon Mar 04, 2013 6:46 am Up
Struts? They mean dampers or the lateral link bars?
PostPosted: Mon Mar 04, 2013 6:56 am Up
I honestly don't know mate, could be the lateral link bars, my local garage noticed they were split when they were fitting my exhaust system
iainlovatt
PostPosted: Mon Mar 04, 2013 7:28 am Up
probably dampers, mine need doing to, touched them and the rubber disintegrated. lol
(My Garage)
PostPosted: Mon Mar 04, 2013 8:43 am Up
LOL well i'll be getting the garage to replace them at some point for some uprated bushes if possible, had got told by the guy who fitted my exhaust they were an mot failure but had the car mot'd today by another guy in the same garage who passed it and they weren't an advisory
PostPosted: Mon Mar 04, 2013 9:11 am Up
Will be the sway bars, they fit from the middle of the axle to the bottom of the hub either side.
PostPosted: Mon Mar 04, 2013 10:46 am Up
the nightmare is over, just been to pick the car up after it's mot and was told the bushes were fine, was told that the posture of the rear of the car was to different when all 4 wheels were off the ground making the mechanic think they were split but when only the rear end was in the air they were fine, so now i can put the money towards sorting out a oil and coolant leak Laughing
PostPosted: Mon Mar 04, 2013 12:23 pm Up
good days mate Very Happy
PostPosted: Mon Mar 04, 2013 12:40 pm Up
yeah for that part but the coolant and oil leak i have is costing me £169 Sad
PostPosted: Fri Mar 08, 2013 2:36 pm Up
why?what is wrong?
PostPosted: Fri Mar 08, 2013 2:53 pm Up
the rocker cover seals have gone as well as clip holding a coolant hose to the rad
PostPosted: Sat Mar 09, 2013 2:40 pm Up
well both are important fix,so you better fix them soon Very Happy
