Online Now [197]:
Visitors: 196
Today: 29962
Total: 138651816
Forums › The Car › 206 Problems › Oil Leak - Head Gasket?
Vandelay2
PostPosted: Tue Mar 05, 2013 5:02 pm Up
Hi, I noticed a small oil leak on my 206, not much but it was'not leaking previously.
I topped up the oil and it was a little milky around the filler Sad
The oil seens mainly around the sump but some some does appear to be coming from near the crank?
Can anyone tell anything much from these pics, my usual mechanic is not availalbe till next week and I need to get to work! Thanks Smile
PostPosted: Tue Mar 05, 2013 6:02 pm Up
Could simply be sump gasket seal, Needs to be checked though. Keep an eye on how much oil your using. I wouldn't worry about a white oil cap necessarily, if your car doesn't get a regular good run, condensation will build up here.
bikesforme
PostPosted: Tue Mar 05, 2013 11:03 pm Up
Looks like its coming from the back of the crank sprocket, so i would say its the crank seal or could be the camshaft seal running down. If its the latter it needs doing asap ,has oil on cambelt not good.
Take the top cambelt cover off, only two 10mm bolts, then shine a touch in behind cam sprocket and you will see it the cam seal is weaping. Also check the front timing belt side head gasket corner, has it could be running down from there like mine is.
I have just replaced both my oil seals, easy job on a 8v, if it needs doing good time too replace timing belt and water pump.
chewbacca
PostPosted: Wed Mar 06, 2013 1:32 am Up
That looks like crank oil seal . Thumb Up
Vandelay2
PostPosted: Wed Mar 06, 2013 2:51 pm Up
Thanks guys, I'll let you know what my mechanic says when I can get booked in.
chewbacca
PostPosted: Wed Mar 06, 2013 3:11 pm Up
If it is the crank oil seal then the timing belt will have to be removed so might be a good opportunity to replace it along with the water pump and auxilliary belt if required. Thumb Up
