Latest: sparrowdclxvi
Overall: 17139
Online Now [127]:
Visitors: 126
Today: 18267
Total: 113057801
Forums › The Car › 206 Problems › What's this brown connector for?
gazza82
PostPosted: Thu Mar 07, 2013 4:03 pm Up
Behind the upper grill is a loose connector. It's brown, and fed with two wires: one green, one yellow. Not the horn connector as that one is white. NOt the fogs as they are in the right place behind the headlamps.
Wondered if it could be an alarm or something to do with a/c (not that my Style has either!).
What is it for? Doesn't seem to fit in anything ... but it could be what it needs to go on got lost in the recent prang.
PostPosted: Thu Mar 07, 2013 4:08 pm Up
Probably the bonnet alarm switch.
SinfulDesignCom
PostPosted: Thu Mar 07, 2013 8:44 pm Up
Peugeot didn't make separate looms for every model, so I expect that this goes to something from a different spec model. There nothing electric-wise at the front for air con, but as Edward said, maybe previous alarm.
Sinful Design - web design, graphic design, web apps, hosting...
My 2003 GTi 180 Track Project Thread
Simmo
PostPosted: Fri Mar 08, 2013 7:34 am Up
Could it possibly be for the electric fan which has some how unplugged?
1.1 silver style www.206info.co.uk/Foru...52484.html
PostPosted: Fri Mar 08, 2013 10:51 am Up
Fan wiring comes from the passenger side.
gazza82
PostPosted: Sat Mar 09, 2013 5:30 am Up
Fans still connected. Bonnet alarm would make sense as it comes from driver side and is about the right length.
Thanks to all for responding!!
PostPosted: Sat Mar 09, 2013 8:53 am Up
Ethernet... or bonnet switch as Ed said from the start.
