Latest: tbafonso
Overall: 17130
Online Now [188]:
Visitors: 188
Today: 24489
Total: 104379773
Forums › The Car › 206 Talk › Mod or not?
Mod or not?
RedHDI
PostPosted: Fri Mar 08, 2013 10:47 am Up
My 206 has 180k miles on the clocks but running smooth. What i want to know is would it be worth my time to do a few mods e.g; Lowering, Rims, gti kit etc. If the engine blows im thinking about either doing a turbo gti conversion and making it a proper sleeper considering its a 5 door and would be so unexpected or the other route is to put in a 1.6 hdi engine and map it with a front mount. Whats peoples opinions on this?
Lewis
PostPosted: Fri Mar 08, 2013 10:52 am Up
sleeper with a turbo conversion.. <3 BOOSTTTT
Tivoli LX 1.1
Black GTI 180
White VXR Burg
Antknee
PostPosted: Fri Mar 08, 2013 11:03 am Up
if you drop a new engine in it don't go for the 1.6 hdi, i would only go for 1.4 or 2.0
20Drift
PostPosted: Fri Mar 08, 2013 11:16 am Up
If the engine blows, do a V6 conversion. Or you could be really, really mechanically clever and try and get this to fit: www.ebay.co.uk/itm/200...53f19c12ee
PostPosted: Fri Mar 08, 2013 11:24 am Up
Just buy the right car to start with and do that. You need thousands to make any 206 fast.
RedHDI
PostPosted: Fri Mar 08, 2013 11:27 am Up
The car is spot on only minor marks around the body that wont cost much to fix. I was thinking for the time being i could lower it around 70mil all round with 205 speedlines or some deep dish superlites
206HdiGti
PostPosted: Fri Mar 15, 2013 8:58 am Up
If you lower it, don't just buy springs, buy new dampers as well.
RedHDI
PostPosted: Fri Mar 15, 2013 9:20 am Up
Any recommendtions for a good setup and any links?
LiamGTi180
PostPosted: Fri Mar 15, 2013 9:43 am Up
I dunno if you are intending on doing the work yourself but even if you are you are looking £1000s. May as well buy a new car. In my own experience going down the engine conversion route is a ball ache
