Latest: ArtistKS
Overall: 17145
Online Now [66]:
Visitors: 65
Today: 9988
Total: 116025356
Forums › The Car › 206 Talk › Any body done there own service on a hdi gti?
vickys.hdi.gti
PostPosted: Thu Mar 14, 2013 9:44 am Up
Looking at doing this myself. can you give me some pointers please? oil type, amount, were the diesel pump is located? do you need to bleed the system.? etc. what is all the parts i will need? car has 64k
Hdi power
Lecktorious
PostPosted: Thu Mar 14, 2013 12:17 pm Up
Trade Rating: +59
Oil type - as per handbook. Why do you need to know where the diesel pump is?
Remember to prime the fuel filter once you've replaced it. You need to remove the rocker cover to get at the manual pump for priming.
'98 Nile Blue 306 GTi 6
vickys.hdi.gti
PostPosted: Thu Mar 14, 2013 1:45 pm Up
sorry i mean diesel filter
Hdi power
Lecktorious
PostPosted: Thu Mar 14, 2013 2:18 pm Up
Trade Rating: +59
It's below the intake for the air filter, you will need to remove it for access.
vickys.hdi.gti
PostPosted: Thu Mar 14, 2013 3:10 pm Up
is it easy to do? should i do it?
am thinking oil and filter, air filter, diesel filter, plugs. any thing else? pollen filter?
will i need to do any thing regarding the turbo when doing an oil change? heard of storys of the turbo running away if staved of oil?
Hdi power
Lecktorious
PostPosted: Thu Mar 14, 2013 3:16 pm Up
Trade Rating: +59
Can't remember, but I didn't have any past experience other than a how-to which I found on here. If you aren't confident though I would take it to a garage.
Oil, air, pollen and diesel filter. Can't remember when the plugs get done. You don't need to touch the turbo either. Using the wrong grade of oil may kill it though.
vickys.hdi.gti
PostPosted: Thu Mar 14, 2013 3:41 pm Up
cheers, just found the how toos on fuel filter and oil change. easy enough. serviced my e46 but never a diesel. looks straight forward though.
Hdi power
206HdiGti
PostPosted: Fri Mar 15, 2013 8:51 am Up
I'm having my mate do my service in 1500 miles time.
Will probably be changing the radiator as well as it's got a hole.
Let us know how you get on with the servicing - as if its a PITA i'll prep him before he starts!
Do you mean fuel filter when speaking about Diesel Filter?
vickys.hdi.gti
PostPosted: Fri Mar 15, 2013 9:49 am Up
yes mate, fuel filter.
Hdi power
