Posted: Fri Mar 15, 2013 9:27 am |
Guys I have a problem that I just cant seem to figure out. The stop light in my car flashes when i hit a bump and the only way to get rid of it is to lock the doors. Anyone able to tell me what the problem is and how to fix it? Thanks in advance folks
| | ![](images/spacer.gif) |
Posted: Fri Mar 15, 2013 9:45 am |
Put it on a code reader and see if any codes are stored is the easiest way otherwise could be anyone of a number of things and would be pure guesswork.
Out of interest, does the interior light come on when the stop light comes on?.
Posted: Fri Mar 15, 2013 10:57 am |
macca1411 wrote: |
Out of interest, does the interior light come on when the stop light comes on?. |
Good thinking as early BSI software versions will flash the STOP if the engine is running & a door is showing as open.
Posted: Fri Mar 15, 2013 11:52 am |
Yeah the interior light comes on and starts to flash as if the door were open
Posted: Fri Mar 15, 2013 11:54 am |
RedHDI wrote: |
Yeah the interior light comes on and starts to flash as if the door were open |
That's why the STOP is flashing then
You have a early BSI software version installed.
Posted: Fri Mar 15, 2013 12:20 pm |
So whats the case then? Please feel free to tell me how it can be fixed
Posted: Fri Mar 15, 2013 1:05 pm |
Check out the door locks as they might be a bit loose if it only starts when you go over bumps ![Wink Wink](images/smiles/icon_wink.gif)
Posted: Fri Mar 15, 2013 1:28 pm |
The door locks are seized. Getting it sorted though
