Online Now [980]:
Visitors: 979
Today: 301094
Total: 149050637
Forums › The Car › 206 Problems › rear abs sensor
rear abs sensor
stewart101
PostPosted: Sat Mar 16, 2013 7:32 am Up
Hi all
First post so be nice
Replaced rear axle on the in laws 206 gti
couldn't get the sensors out of the original one and the replacement someone had cut the connectors
had to smash them out so i could get the car back together so she could use it for work.
so what sensors fit for example will a 1.1 sensor fit a 2.0 gti?
thanks people
regards
stewart
PostPosted: Sat Mar 16, 2013 3:25 pm Up
well if the 1.1 rear axle is the same as the 2.0 GTi,i mean the breaks calipers,and discs or it got drums and break shoes,so if it's the same as the GTi,then i think there is no problem,but make sure it got discs.
PostPosted: Wed Mar 20, 2013 4:36 pm Up
so did u managed to fix it?
PostPosted: Wed Mar 20, 2013 7:36 pm Up
Depends on if plexed or not, And even then I think there's four connector types.
