Latest: Puggingalong
Overall: 17129
Online Now [565]:
Visitors: 564
Today: 61401
Total: 101483535
Forums › The Car › 206 Problems › Indicator + Lights coming on and off problems eek!
beccaboo98
PostPosted: Mon Mar 18, 2013 6:20 am Up
Hi just wondering if anyone can help and give me some advice.
My annoyingly temperamental indicators seem to just stop working half way through being turned on, which can be dangerous (and i've had some dodgy looks for not indicating when i actually am!).. Also my lights seem to flick on and off like they've got a mind of their own, which i wouldn't care about apart from sometimes people think im flashing and i'm not! Sad
I also don't know if the car is pre-plex or multi-plex, it is a 2003 model with the radio stork/radio controls stork. Im guessing this could be easy or an expensive job.
Can anyone please help?? Thank you! Very Happy
ryanovsalford
PostPosted: Mon Mar 18, 2013 6:43 am Up
sounds like it could be water in the rear light take the leense off and see if its wet chances are that the board which you mount the bulbs into could be wet they are cheap enigh to get from scrappy about 5-10 quid see if that sorts it
Mr-Tigger
PostPosted: Mon Mar 18, 2013 8:09 am Up
willing to stake a quid that its the stalk. mine,and many others did/do this. shavings from metal contact inside the stalk cause it to switch to high beam. when indicating right usually? i think at 2003 you have the sealed type stalk which means removing airbag etc so not an easy at-home job unless you know what you're doing. if you have the sidelights on do they work fine?
beccaboo98
PostPosted: Mon Mar 18, 2013 10:15 am Up
onYeah it goes to high beam, usually indicating left for me but does it to the right also, or even when im not indicating and just on a straight road the lights come on and off themselves. It's just very temperamental. I have noticed it doesn't do it when i've got the sidelights on. I thought myself it might be something to do with the stork with the indicator problems too but i wasn't sure.
Mr-Tigger
PostPosted: Mon Mar 18, 2013 10:40 am Up
yeah the two will be linked, try outting sidelights on then indicating,see if it works properly. i just drove around with sidelights on. modded lights so looked cool anyway lol
PostPosted: Mon Mar 18, 2013 10:58 am Up
Com 2000 unit wants replacing, buy a NEW one, 2nd hand / used ones are not worth the hassle.
beccaboo98
PostPosted: Mon Mar 18, 2013 11:57 am Up
Well it seems to solve the problem with putting my sidelights on lol, sounds a cheap and cheerful solution!
beccaboo98
PostPosted: Mon Mar 18, 2013 11:58 am Up
How much would i be looking at for a com 2000 unit? I've heard they're expensive!
Tolkienfan001
PostPosted: Mon Mar 18, 2013 12:15 pm Up
Trade Rating: +13
About £150 from carparts4less.....
2005 1.4 16v Sport
Check out my 206 here!
