Posted: Mon Mar 18, 2013 1:17 pm |
hi every1 can anyone help i bled the braking system but still very spongey i bled from furthest away to nearest several times put 2 new rear wheel cylinders front pads .get very good pedal until start car then it goes down but if pump pedal the strength comes back but pedal slowly goes down .
Posted: Mon Mar 18, 2013 2:10 pm |
Sounds normal to me unless you not having to use much force to have the pedal hit the floor
Posted: Tue Mar 19, 2013 5:37 am |
the brakes really rubbish holding just at the bottom /i use eezibleed to pressurize the master cylinder then the brakes are brilliant what does this mean
Posted: Tue Mar 19, 2013 7:27 am |
Air trapped in the system
Posted: Tue Mar 19, 2013 8:03 am |
As above air trapped still
Posted: Tue Mar 19, 2013 9:23 am |
Was this problem there before you did the work on the brakes.
| 206 2ltr Hdi glx 53 plate | |
Posted: Tue Mar 19, 2013 9:53 am |
Agree wth other posters just sounds like you still have air in the system
Posted: Tue Mar 19, 2013 9:56 am |
| m4rcus66 wrote: |
| i use eezibleed to pressurize the master cylinder |
How much air pressure are you using with the Eezibleed?
