Online Now [313]:
Visitors: 312
Today: 42818
Total: 142755162
Forums › The Car › 206 Problems › brakes
brakes
m4rcus66
PostPosted: Mon Mar 18, 2013 1:17 pm Up
hi every1 can anyone help i bled the braking system but still very spongey i bled from furthest away to nearest several times put 2 new rear wheel cylinders front pads .get very good pedal until start car then it goes down but if pump pedal the strength comes back but pedal slowly goes down .
usher
PostPosted: Mon Mar 18, 2013 2:10 pm Up
Sounds normal to me unless you not having to use much force to have the pedal hit the floor
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
m4rcus66
PostPosted: Tue Mar 19, 2013 5:37 am Up
the brakes really rubbish holding just at the bottom /i use eezibleed to pressurize the master cylinder then the brakes are brilliant what does this mean
usher
PostPosted: Tue Mar 19, 2013 7:27 am Up
Air trapped in the system
project thread WIP
garage
FAQ
206 gti firedance
Jeffers
PostPosted: Tue Mar 19, 2013 8:03 am Up
As above air trapped still
DREWDEN
PostPosted: Tue Mar 19, 2013 9:23 am Up
Was this problem there before you did the work on the brakes.
206 2ltr Hdi glx 53 plate
chewbacca
PostPosted: Tue Mar 19, 2013 9:53 am Up
Agree wth other posters just sounds like you still have air in the system
PostPosted: Tue Mar 19, 2013 9:56 am Up
How much air pressure are you using with the Eezibleed?
