Latest: tebas93089
Overall: 17179
Online Now [540]:
Visitors: 539
Today: 30985
Total: 137882354
Forums › The Car › 206 Problems › 206cc 2.0 wont rev properly and loosing power
Go to page 1, 2, 3  Next
chris_loader
PostPosted: Tue Mar 19, 2013 1:26 pm Up
i have a 206cc 2.0 16v and it has just started doing this,
you drive along with you foot just touching the trottle and it will rev but if you put your foot any further down the car will start juddering and loose power, this will happen in every gear and also when you are sat still i try to rev and if i just tap the trottle it will climb slowly but if i put my foot any further down it ill rev then drop to about 1500 - 2000 and stay there with my foot to the floor and start reving between 1500 and 2000
i first thought there was not enough air getting in but it still does it with the air box off
the car has brought up some messages in the past on the centre screen
first was somthing to do with the cat and the other was anti pollen fault
i do hope some one will be able to help me with this
thanks
206cc 2.0 16v
PostPosted: Tue Mar 19, 2013 1:29 pm Up
Needs scanning for fault codes.
ANTIPOLLUTION FAULT mean's the engine ecu has detected a problem, you need to read the fault codes stored in the memory.
Fault codes will point you in the direction of the problem.
chris_loader
PostPosted: Tue Mar 19, 2013 1:33 pm Up
i did scan it and first of all came up with 2 knock sensor faults and one other that i cant remember but i cleard them off and took it for a drive and still no change then i plugged it in again and it came up with p0170
206cc 2.0 16v
Mr-Tigger
PostPosted: Tue Mar 19, 2013 1:47 pm Up
going through this same thing myself,however its intermitten and p0201 and p0202 faults,going back to the garage,hope yours isnt a serious/beggared as mine dude. but that could just be related to MAF or something else toying with the fuel mix
chris_loader
PostPosted: Tue Mar 19, 2013 1:49 pm Up
see i thought i would be maf but mine does not have a maf it only runs a map
206cc 2.0 16v
chris_loader
PostPosted: Tue Mar 19, 2013 1:50 pm Up
it*
206cc 2.0 16v
chris_loader
PostPosted: Tue Mar 19, 2013 1:53 pm Up
but my mate had a 406 with the 2.0 in and he had isues with it dieing and irratic idle with was down to the maf
206cc 2.0 16v
chris_loader
PostPosted: Tue Mar 19, 2013 1:55 pm Up
its my girlfrinds car and i tell her to tell me any symtoms it has but she never does but it did used to come up with a cat fault on the centre screen but it passed mot exhaust gas test
206cc 2.0 16v
PostPosted: Tue Mar 19, 2013 1:59 pm Up
Here's a guess. It's the coil pack. Will run fine at idle but the coil pack is too weak to spark through the denser air at anything more than idle...as I said just a guess.
chris_loader
PostPosted: Tue Mar 19, 2013 2:02 pm Up
but i presume they are expensive as its a single solid coil pack Sad
206cc 2.0 16v
chris_loader
PostPosted: Tue Mar 19, 2013 2:04 pm Up
would it not missfire if the cylinder couldnt spark under load
206cc 2.0 16v
PostPosted: Tue Mar 19, 2013 2:05 pm Up
Hasn't got w**ky NGK spark plugs in it?
chris_loader
PostPosted: Tue Mar 19, 2013 2:09 pm Up
i did pull them out today but cant remember what make they are but my first thought was to give it a new set of plugs
206cc 2.0 16v
chris_loader
PostPosted: Tue Mar 19, 2013 2:40 pm Up
when i held the trottle wide open and it was reving around the 2000 mark i put my hand over part of the tube that goes to the air box and the revs did pick up a little which is making me think more of a air leak somewhere
206cc 2.0 16v
PostPosted: Tue Mar 19, 2013 2:51 pm Up
£102 for a coil pack from Euro Car Parts. Can get 25% discount on that though.
Page 1 of 3
