Posted: Fri Dec 28, 2012 5:56 am |
you are a genious mate! thank you soo much! best xmas present ever! cheers
Posted: Fri Dec 28, 2012 5:57 am |
Good good have a good new year!
Posted: Fri Dec 28, 2012 6:03 am |
What a thread! You bickered like hell, then were best mates! Red and yellow swap was my first guess, been covered a hundred times before!
and you!
Posted: Fri Dec 28, 2012 7:28 am |
Steve206 wrote: |
What a thread! You bickered like hell, then were best mates! Red and yellow swap was my first guess, been covered a hundred times before! |
Puppy Love?
Posted: Fri Dec 28, 2012 7:37 am |
The op didnt explain properly that it was a memory issue, simply said it's not working and needed a permanent live...
Wasn't until later memory was the issue
Posted: Fri Dec 28, 2012 8:06 am |
DeadEyePaul wrote: |
Wasn't until later memory was the issue |
djoggie wrote: |
Hi all.
Ive just installed a new Head Unit but it wont work.
Halfords have said i need to take the cable attatched the the rest of the cables to a perminant live? there is a ignition switch already there but i need a perminant live for the memory???
I have got the cable to under the steering wheel on my 206 but not sure how to identify a live?
i hate driving without music and i do alot of driving for work....
i start work again on wednesday so need this done asap!
any help would be appreciated!
Thanks |
OP quite clearly says memory is the issue.
Posted: Fri Dec 28, 2012 6:42 pm |
LeeThr wrote: |
djoggie wrote: |
Hi all.
Thanks |
OP quite clearly says memory is the issue.  |
He forgot..
Posted: Mon Jan 07, 2013 3:15 pm |
Hi there, i had the same issue as i put in a sony head unit. When using a test meter on the car side of the wiring it showed i had a permanent live but after about 30 secs it turned of thus loosing all the settings. I had a few optins like running a live from the battery but i went for the easier option and spliced into the permanent live from the ignition barrel wiring (thick pink wire) and connected straighto the head units yellow wire. now all is fine.
Posted: Wed Mar 20, 2013 10:02 am |
Do you have a connector like this?
You need red going into yellow |
Hi mate, to swap these over, do you just pull them out of the connectors? I've never dealt with electronics before, so don't want to force something and break it lol, cheers.
Posted: Wed Mar 20, 2013 10:06 am |
Yeah pull outand swap them around
Posted: Wed Mar 20, 2013 3:44 pm |
Yeah pull outand swap them around |
All done, thanks. Was so easy I feel a bit daft for asking
Posted: Wed Mar 20, 2013 3:48 pm |
Its aliirght we all have to learn somewhere
Posted: Wed Mar 20, 2013 4:23 pm |
Its aliirght we all have to learn somewhere  |
Ha yes true. Thanks again, you've saved me roughly 1 minute of setting adjustment per journey for the entire time I have the car.
