Latest: jackrox1992
Overall: 17186
Online Now [925]:
Visitors: 924
Today: 91757
Total: 148622428
Forums › The Car › 206 Problems › fuel guage
fuel guage
twed207
PostPosted: Thu Mar 21, 2013 8:18 pm Up
hi all,
got a problem with my newly aquired 206. the fuel guage moves and stuff when you switch the ignition on but it's just above a quater of a tank and the fuel light came on so i think the sender is working, just the needle is playing up..?
is there anything that can be done or is it a case of getting new dials?
cheers
twed.
206 2.0HDi
My 207 WIP
Turbo Diesel Owners Club UK
L200 thread
twed207
PostPosted: Thu Mar 21, 2013 8:20 pm Up
and i think the temp guage might be a little out too? it sits at about 75deg. my last one used to sit at 82 ish and so did my 207...
206 2.0HDi
My 207 WIP
L200 thread
PostPosted: Fri Mar 22, 2013 3:06 am Up
well you might need a new thermostat so the gauge sit at 82 ish,and about the fuel gauge,you need to check the sender on the fuel pump
twed207
PostPosted: Fri Mar 22, 2013 4:03 am Up
ah, i forgot to mention that when the engine is off, the fuel needle doesnt quite rest at the bottom against the pin, it sits just up from it...
206 2.0HDi
My 207 WIP
L200 thread
tsotd
PostPosted: Fri Mar 22, 2013 4:10 am Up
my fuel light is the same, it comes on at quater of a tank, just thought it was normal
Topaz 2.0 16v 205 Gti6 (ph1.5)
Mercury 2.0 16v 206 Gti (ph1)
twed207
PostPosted: Sat Mar 23, 2013 2:28 am Up
anyone else?
206 2.0HDi
My 207 WIP
L200 thread
PostPosted: Wed Mar 27, 2013 6:38 am Up
twed207 wrote:
anyone else?
Yes, me.
If it's multiplexed (Oct 2001 >) reset the BSI and if that solves it go to a dealer for an ECU and BSI software update.
Quasar911
PostPosted: Wed Mar 27, 2013 7:49 am Up
how much will a desler charge to Update the ECU and BSI ?
I have a x reg 2 litre HDI TD which the ECU has not been updated since.
