Latest: Kifi69
Overall: 17183
Online Now [357]:
Visitors: 356
Today: 168207
Total: 144008174
Forums › The Car › 206 Talk › Gearbox Whine?
Gearbox Whine?
RyanC206
PostPosted: Mon Mar 25, 2013 1:36 pm Up
Hi everyone, new to the forum. Had an MG but now moving to a Pug!
Anyway, I have a strange sound/squeak coming from the gearbox (I assume)
It is noticeable when idle when the engine is cold, as well as when accelerating the whine gets faster. However the sound disappears in 3rd gear onwards.
Any ideas? I thought clutch release bearing but it seems that it isn't clutch related.
gtijames22
PostPosted: Mon Mar 25, 2013 2:24 pm Up
whats the mileage mate?
GTI 180 JIM
Sadako
PostPosted: Mon Mar 25, 2013 4:57 pm Up
if it ain't clutch releas bearing either bearings in box or diff
RyanC206
PostPosted: Wed Mar 27, 2013 11:23 am Up
70000 miles or there abouts.
206Matt
PostPosted: Wed Mar 27, 2013 11:41 am Up
I had a similar issue to this with mine and thought it would be the release bearing but after changing that and the clutch it didnt go away so I had to get the box refurbed!
Deano
PostPosted: Wed Mar 27, 2013 2:57 pm Up
i had similar probably a top up of oil did the job mate
tsotd
PostPosted: Thu Mar 28, 2013 3:26 am Up
top up the oil first then go from there, if the noise goes away in the higher gears i wouldnt of thought it would be the clutch
Topaz 2.0 16v 205 Gti6 (ph1.5)
Mercury 2.0 16v 206 Gti (ph1)
RyanC206
PostPosted: Thu Mar 28, 2013 10:49 am Up
thanks all.
any particular transmission fluid that I should use
TTnTT
PostPosted: Thu Mar 28, 2013 12:06 pm Up
How hard is it to replace cluth bearings or how much would it roughly cost to have done?
