Forums › The Car › 206 Problems › 206cc 2.0 wont rev properly and loosing power |
Posted: Tue Mar 26, 2013 11:55 am |
right today found a mate's gf who has the same car and i borrowed a few bit, first i tried coil pack but no luck, then tried plugs and no luck the swaped the map sensor but still nothing finally i swaped the whole trottle body over but nothing.
this is a real pain as its getting worse when i put my foot down it will rev a little and sometimes cut out not and not catch
i have read that in the winter time somthing to do with water in the fuel and to put some vpower in
Posted: Tue Mar 26, 2013 12:50 pm |
This doesnt have a motorised throttle body does it? Would think it's too early for that.
Posted: Wed Mar 27, 2013 3:59 am |
Its cable throttle
