Latest: jackrox1992
Overall: 17186
Online Now [588]:
Visitors: 587
Today: 99251
Total: 148473136
Forums › The Car › 206 Talk › Jacking points
Jacking points
Forum Index › 206 Talk
hellopeople
PostPosted: Wed Mar 27, 2013 7:16 am Up
I jacked up my car on the jacking points only for it to collapse. Has anyone else had this problem? Would it be easy to sort out?
Garry
PostPosted: Wed Mar 27, 2013 7:27 am Up
Where you using the factory provided jack in the correct jacking point?
The jacking points are clearly marked on the lower sill edge.
PostPosted: Wed Mar 27, 2013 7:31 am Up
Take it you have folded the seam over. The Peugeot supplied jack has a recess in it to prevent this. Trolley jacks hold all the weight of the car on a strip of metal a few millimetres wide.
Hammer it straight again if you can and then fabricate something for the top of your trolley jack to stop it happening again.
PostPosted: Wed Mar 27, 2013 7:45 am Up
Trolley jack and a big block of timber under the box sections on the floor works perfectly.
hellopeople
PostPosted: Wed Mar 27, 2013 7:49 am Up
Yeah I was using the correct Jacking points under the sill edge. yeah I folded the seem over. Its I will modify the jack. Thanks. Garry.
PostPosted: Wed Mar 27, 2013 7:51 am Up
The sill jacking points are for use with the factory supplied jack ONLY!
tsotd
PostPosted: Thu Mar 28, 2013 3:08 am Up
factory jack on the sill points, trolly jack on the sub frame.....if your car isnt too low
Topaz 2.0 16v 205 Gti6 (ph1.5)
Mercury 2.0 16v 206 Gti (ph1)
PostPosted: Thu Mar 28, 2013 4:37 am Up
even using the factory jack on the proper jacking points still isn't secure enough as I found out on the moonstone, peugeot should have made better jacking points
wifes206
PostPosted: Tue Apr 02, 2013 6:24 pm Up
I use factory jacking points with my trolly jack,
I use a little piece of wood with a good size groove cut out of it
206 2.0hdi(04)
PostPosted: Wed Apr 03, 2013 6:22 am Up
I don't get it.
I've been using trolley jack on the jacking points for years and not even so much as a click heard ever.
What surface was this on? Tarmac? drive?
hellopeople
PostPosted: Sat Apr 06, 2013 9:25 am Up
Mine problem was on tarmac. Seems a few people have this problem though.
usher
PostPosted: Sat Apr 06, 2013 12:47 pm Up
sub frame where the wishbone bolt is and rear beam mounting bolt work perfectly well for me but have to go up some home made ramps for the front first as its too low for the jack to get under
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
