Online Now [541]:
Visitors: 540
Today: 125045
Total: 105566987
Forums › The Car › 206 Problems › Cylinder head help please
bikesforme
PostPosted: Thu Mar 21, 2013 4:46 am Up
Hi, I have a 2001 1.4 lx petrol 206 and the part number on my head is 9634005110. I have brought another head to rebuild has mine is leaking oil at head gasket slightly, its got the same part number but was removed from a 2005 1.4 c3.
On putting my inlet gasket on from my gasket kit, it does not line up proper, can anyone tell me if i have the wrong head or wrong gasket set.
oldskoolz
PostPosted: Thu Mar 21, 2013 5:14 am Up
different years of TU engine had different inlet port spacing. early models had 00-00 spacing while later models had 0-0-0-0. also the TU engine often has leaks, its not that much of an issue
Black 206 Gti. Soon to be 2.2
bikesforme
PostPosted: Thu Mar 21, 2013 5:32 am Up
This is a photo of the c3 inlet and my new gasket, how do i get it to fit my 2001 206 if spacing is different, or have i got the wrong gasket. Thanks
PostPosted: Thu Mar 21, 2013 10:03 am Up
Why buy a replacement head? Confused
If the original one is sound just get it skimmed & refit it.
bikesforme
PostPosted: Thu Mar 21, 2013 1:17 pm Up
The reason i did not do the original head is because i use the car daily and can not have it off the road long. I saw this head off ebay and its been skimmed but never put back on car and was cheap .
My plan was to reground the valves and port the exhaust and inlet to match the gbaskets
PostPosted: Thu Mar 21, 2013 1:53 pm Up
Sure that's not an exhaust gasket?
bikesforme
PostPosted: Tue Mar 26, 2013 1:57 pm Up
The other gasket is a metal one too, anyone no if the inlet gasket is metal.
PostPosted: Tue Mar 26, 2013 2:55 pm Up
On a metal manifold the inlets tend to use the stuff that resembles cardboard.
bikesforme
PostPosted: Wed Mar 27, 2013 3:26 pm Up
Not got a clue then, there is some rubber rings in the kit too, would that be the inlet gaskets and perhaps the kit comes with two different types of exhaust gaskets .
PostPosted: Wed Mar 27, 2013 4:20 pm Up
Rubber rings tend to be for plastic inlet gaskets.
bikesforme
PostPosted: Wed Mar 27, 2013 11:38 pm Up
I am sure my inlet is plastic .
bikesforme
bikesforme
PostPosted: Thu Mar 28, 2013 2:27 am Up
This is a picture of my other gasket, the bottom gasket fits the exhaust manifold fine, not sure if both gaskets are for exhaust manifold and the kit comes with 2 to cover other type.
My inlet manifold is plastic, been told that this head is for a plastic inlet manifold but there are 2 types of plastic inlet manifolds.
This is the inlet side of head, bearing in mind the head is upside down, if anyone can help.
bikesforme
PostPosted: Tue Apr 16, 2013 10:56 am Up
Head is on and all fitted well and runs great, the kit came with 2 different exhaust gaskets . The injectors are little noisy but i have just brought 4 brand new ones waiting to put in when i have the time. Car seems to be better on fuel now, headgasket was well gone.
PostPosted: Tue Apr 16, 2013 3:05 pm Up
Mate...
It is NEVER the injectors.
It's always the valves that need adjusting carefully and repeatedly over 1000 miles or so.
Then you'll be cooking. Cool
