Latest: Kifi69
Overall: 17183
Online Now [1298]:
Visitors: 1297
Today: 179733
Total: 144807728
Forums › The Car › 206 Problems › Turbo Problem ? - Car is running fine
Quasar911
PostPosted: Wed Mar 20, 2013 11:50 am Up
Hi,
Peugeot 206 HDI 2 litre Turbo Disel, X reg.
I have noticed that in mornings and after long stops, the car is very sluggish - almost in limp mode and wont go over 2k revs., some times not even in limp mode, just appears to b no turbo.
after about 5 miles or so all appears to be fine and then the turbo kicks in and the car is fine for the rest of a journey however long it may be.
Any Ideas ?
PostPosted: Wed Mar 20, 2013 4:23 pm Up
get it scanned to see if there is any sensors going faulty
Quasar911
PostPosted: Thu Mar 21, 2013 5:00 am Up
What scanner connector is it ?
I have and CAM II ( ODB II ) scanner which is like a small scart, ( bought it when i had a mazda 6 )
PostPosted: Fri Mar 22, 2013 3:57 am Up
you can use it to scan it,and give me the codes ,will help u out
Quasar911
PostPosted: Wed Mar 27, 2013 4:22 am Up
Hi Again,
Finally got hold of my CAN ODB2 reader back.
now from what i can gather there are 2 codes. One that can be cleared and the turbo kicks in fine.
the other cannot be cleared by the reader but does sometimes go off on its own accord,
the code that stays on is P0903, i am not sure yet what the other code is as it clears.
With this code up, the car runs normal and not having any issues,
Any Ideas ??
Regards
Kev.
Quasar911
PostPosted: Thu Mar 28, 2013 7:44 am Up
Shamesless Bump.
