Latest: lio94
Overall: 17181
Online Now [81]:
Visitors: 80
Today: 14029
Total: 141324813
Forums › The Car › 206 Problems › 206 Speed Sensor Replacement
nellyhaggis
PostPosted: Thu Mar 28, 2013 5:06 pm Up
As detailed above.
Has anyone changed the speed sensor on a 206 before?
Just wondering where it is as Ive got a P0500 fault so it will need to be replaced.
Its on a 1.6 hdi but I assume they are all in the same kind of place.
Cheers.
- Sinature removed due to size.
Please feel free to upload one of the correct dimensions.
PostPosted: Thu Mar 28, 2013 5:10 pm Up
Do these have it on the gearbox?
hayes_ctfc
PostPosted: Thu Mar 28, 2013 5:12 pm Up
I believe they're on the top of the gearbox. It's a 616070 part numbe, so the common one
OLD: Peugeot 206 2.0 GTi 138
NEW: Seat Leon FR TDi 170
nellyhaggis
PostPosted: Thu Mar 28, 2013 5:26 pm Up
I aint got a clue where they are.
If they are on the gearbox I take it they are at the flywheel end and take the signal from that?
PostPosted: Fri Mar 29, 2013 2:32 am Up
It's on the final drive at the back of the gearbox. It's a battery out job to access it.
tsotd
PostPosted: Fri Mar 29, 2013 8:31 am Up
its on top of the diff (well on my 206 it is)
it plugs into part no2
Topaz 2.0 16v 205 Gti6 (ph1.5)
Mercury 2.0 16v 206 Gti (ph1)
SWHdi
PostPosted: Wed Apr 03, 2013 2:35 pm Up
Just to let you know, my 2.0 hdi was supposed to have it on the final drive, but it didn't, ended up it was the front driver side abs sensor, which the speedo gets it's signal from, (if I remember correctly it has 2 wires going into the abs sensor plug)
Curse you Airbag light!!
nellyhaggis
PostPosted: Mon Apr 29, 2013 5:23 am Up
Right.
I've just spoke to peugeot and the sensor is actually at the timing belt side of the engine and that try hardly ever go wrong but to check the gap between the sensor and the crank.
Failing that it could be the wiring in the fuse box in the inner wing.
Would anyone know if the abs fault I've got at the moment would have anything to do with the speed sensor fault?
PostPosted: Mon Apr 29, 2013 5:27 am Up
So is your speedo not working (sensor on gearbox) or is it engine speed sensor (on the block)?
nellyhaggis
PostPosted: Sun Jun 23, 2013 6:04 pm Up
turns out that i needed 2 new abs rings and a speed sensor which was behing the bottom pulley drivers side.
Ended up with 2 new cv joints thou as they were dirt cheap on ebay.
Running like it should now at last.
