Latest: ArtistKS
Overall: 17145
Online Now [76]:
Visitors: 75
Today: 1196
Total: 116058156
Forums › The Car › 206 Problems › Oil Temp in red when stationary
fatpies
PostPosted: Mon Apr 01, 2013 8:58 am Up
Hi there,
Recently encountered a problem with the 206, whilst the engine is on and the car is stationary, the oil temp seems to rise into red after about 4-5 mins. Once driving again it does back down to normal.
Could anyone advise me what the issue is here? I'm assuming it could be that the cooling fan is turning off when the car isn't moving, but I haven't checked this yet.
Cheers
PostPosted: Mon Apr 01, 2013 9:30 am Up
Oil or water? Fan doesn't affect oil temp, and oil temp would rarely rise to the red.
fatpies
PostPosted: Mon Apr 01, 2013 10:51 am Up
Water temp rather, sorry - i'm new to this car business
PostPosted: Mon Apr 01, 2013 11:06 am Up
Do you have a/c. See if your fan works when the a/c is on.
PostPosted: Mon Apr 01, 2013 11:19 am Up
Air lock in the coolant system, or radiator fan, or low in coolant.
PostPosted: Mon Apr 01, 2013 1:23 pm Up
or the thermostat is stuck closed Sad
fatpies
PostPosted: Mon Apr 01, 2013 1:36 pm Up
Sounds like it could be a variety of problems. Will check the a/c and coolant tomorrow.
If it is a case of any of the above, any idea how much a repair would cost?
fatpies
PostPosted: Mon Apr 01, 2013 1:38 pm Up
Was in an accident a few weeks ago where the front was knocked a bit, and the radiator could possibly be damaged. It's had a once over but I suspect this could be the problem..
karimali831
PostPosted: Mon Apr 01, 2013 1:55 pm Up
When this happened to me the cooling wiring harness corroded, check this also.
206 GTI 180
PostPosted: Mon Apr 01, 2013 2:32 pm Up
Thermostat has failed
