Latest: tebas93089
Overall: 17179
Online Now [122]:
Visitors: 121
Today: 26312
Total: 138287138
Forums › The Car › 206 Talk › How do i change my sump? GTI 138
pnut_man
PostPosted: Fri Apr 12, 2013 12:30 pm Up
Hey guys, need some help with my sump, wondering if there is a walk through on here or if there is some helpful chap out there who would briefly talk me through it. Its a 2002 206 GTI 138. Help would be much appreciated!
macj
PostPosted: Fri Apr 12, 2013 1:19 pm Up
fairly simple if you are fairly good at mechanics. Problem bolts are those at the bell housing end which need a long thin socket to reach them.
It pays to check you can access all bolts before you start then work your way around them with something supporting the sump pan. A small amount of sealer is required for re-assembly.... the dipstick tube also needs to be removed to aid your progress
pnut_man
PostPosted: Fri Apr 12, 2013 3:05 pm Up
I think I can tackle it, cheers for the advice. I have heard that parts of the air con system are in the way, is this correct?
macj
PostPosted: Sat Apr 13, 2013 1:34 am Up
possibly.... I don't have it on the rally car
PostPosted: Sat Apr 13, 2013 2:00 am Up
It's just the lower bolts on the air con pump. Just take them out.
