Posted: Tue Apr 16, 2013 10:47 am |
Hi.Does anyone no where i can get the spring clip for the spring clip connectors. Been looking on ebay with no joy.
Posted: Tue Apr 16, 2013 12:55 pm |
What are spring clip connectors? Same as Junior Power Timers?
Posted: Tue Apr 16, 2013 1:05 pm |
Edward wrote: |
What are spring clip connectors? Same as Junior Power Timers? |
The clips that are held together with a u shape spring clip, ie the air con connector. I am after the u shape clip, easy to lose.
Posted: Tue Apr 16, 2013 2:04 pm |
Sounds like you mean Junior Power Times plugs.
Posted: Tue Apr 16, 2013 9:01 pm |
Edward wrote: |
Sounds like you mean Junior Power Times plugs. |
Did not no they were called that, just after the spring clip.
Posted: Wed Apr 17, 2013 6:08 am |
Try the Peugeot dealer. The can get just the plugs for the wiring looms. You might not be able to just get the clip on its own though.
