Latest: tbafonso
Overall: 17130
Online Now [293]:
Visitors: 292
Today: 47188
Total: 104097868
Forums › The Car › 206 Talk › 180 accelleration whistle
PostPosted: Fri Apr 19, 2013 4:17 pm Up
Noticed recently that whenever i accellerate in 1st, 2nd and 3rd gear there is a whistling noise, even with a janspeed fitted it's quite noticeable
PostPosted: Fri Apr 19, 2013 4:31 pm Up
like from the engine bay,or wheels?
PostPosted: Fri Apr 19, 2013 4:38 pm Up
Could be auxilary belt slip.
PostPosted: Fri Apr 19, 2013 4:50 pm Up
From the engine bay
broadblaster
PostPosted: Sat Apr 20, 2013 2:04 am Up
maybe small air leak around the box lid or if ind kit fitted a clamp not tight enough.
on a back road playing
Tolkienfan001
PostPosted: Sat Apr 20, 2013 2:32 am Up
Trade Rating: +13
What He Said
2005 1.4 16v Sport
Check out my 206 here!
PostPosted: Sat Apr 20, 2013 4:19 am Up
I did fit a k&n panel filter recently but it was doing the whistle before that, it won't do any damage will it if left because at some point I will be fitting a k&n typhoon
PostPosted: Sat Apr 20, 2013 4:30 am Up
Depends whats causing it. My sisters clio was whistling from the aux belt, a slight tighten and it was fine.
PostPosted: Sat Apr 20, 2013 4:52 am Up
thanks for the info guy's, it's going into the garage soon to have new rear brake pads so might get them to have a look
