Latest: airmastertapes
Overall: 17133
Online Now [76]:
Visitors: 75
Today: 83490
Total: 106795342
Forums › The Car › 206 Problems › Lambda sensor removal
Go to page Previous  1, 2
PostPosted: Fri Apr 19, 2013 2:56 pm Up
MrBSI wrote:
bikesforme wrote:
i just feel the brakes are the only thing that let the car down now. I have changed the brake fluid but to be honest they didnt make any difference, they just need more feel; bite.
That's down to the right hand drive design.
I wouldn't mind to have a go in a left hand drive 206 & see what the brake feel is like with the pedal directly connected to the master cylinder & not through a transfer linkage.
I have driven 1000's miles in both ABS and non-ABS 1.4i 206 LHD.
My non-ABS became brilliant, absolutely rock solid brake pedal and good stopping distance when I replaced disks and pads with Brembo.
I always assumed that the Mrs. ABS one had floppier brakes because of standard parts, but maybe ABS has something to do with it.
Also, I understand ABS model needs to be bled using PP2000 idealy, which I have never got round to doing as I didn-t have the interface when replacing the brake fluid back then.
bikesforme
PostPosted: Sat Apr 20, 2013 2:17 am Up
My partner has a 52 plate 1.4 hid 206 and her brakes feel better then mine, doing clean and put new seals in the spare front brakes i have and fit them with set grove discs see if that improves things.
I have never looked at the rear brakes, so perhaps worth cleaning out and checking too.
Page 2 of 2
