Latest: cogeim7
Overall: 17185
Online Now [479]:
Visitors: 479
Today: 165177
Total: 147453726
Forums › The Car › 206 Problems › Immeditate help required - car won't start
LiamGTi180
PostPosted: Tue Apr 23, 2013 4:20 pm Up
The car wont start and has the following symptoms - oh and its a 54, gti 180
Turns over but wont start
Wont jump or bump start
Remote locking, stereo and headlights not working
Interior light, windows operate as normal
It is low on fuel but says few miles to refill
Also had slipping aux belt recently so suspecting battery
Any ideas on how to get it going?
Thanks Liam
PostPosted: Tue Apr 23, 2013 4:23 pm Up
Hmmm you jump started it recently?
You need to have a look on a laptop to see if the ecu/bsi is unlocking and whether the cam and crank are syncd
LiamGTi180
PostPosted: Tue Apr 23, 2013 4:35 pm Up
Cheers mate seems likely as everything that runs through bsi such as locks, windscreen wipers and headlights are not working
PostPosted: Tue Apr 23, 2013 4:36 pm Up
Also check your bsi fuses, one could have blown causing non start. Common thing ive found with multiplex and enthusiastic people who touch s**t
broadblaster
PostPosted: Wed Apr 24, 2013 12:40 pm Up
as above i would be checking the fuses before any thing else.
on a back road playing
PostPosted: Wed Apr 24, 2013 2:43 pm Up
Won't be the battery if it continues to turn the engine over in a healthy manner.
LiamGTi180
PostPosted: Sat Apr 27, 2013 4:42 pm Up
Fuses are all fine. Got them tested by the breakdown. Gunna plug it in and see what I can find. Thanks
