Online Now [300]:
Visitors: 300
Today: 100661
Total: 142368705
Forums › The Car › 206 Talk › help............
help............
mj1704
PostPosted: Thu Apr 25, 2013 11:17 am Up
new to site and i have checked this out but cannot find the answer, got a 1999 1.1 pug all was well but heater wouldn't get very hot so i changed thomosat heater then worked well no overheating but ever since has started to rev on its own ok when cold ok when warmed up but always in the middle is when it starts cleaned out throttle no air leaks any help would be great thanks
mj1704
PostPosted: Thu Apr 25, 2013 12:14 pm Up
come on someone must have an answer even with the spelling errors,
mj1704
PostPosted: Thu Apr 25, 2013 12:27 pm Up
back to google then thought you lot might help?
PostPosted: Thu Apr 25, 2013 12:35 pm Up
Mate, most are at work and youve posted three times within an hour, calm down
Did you bleed the cooling system?
PostPosted: Thu Apr 25, 2013 12:36 pm Up
Think some of these are yours .....,,,,,,
Did a quick search on your behalf and found this.
www.206info.co.uk/Foru...c/t=36203/
PostPosted: Thu Apr 25, 2013 2:01 pm Up
Putting help as the thread title = NFI.
Threads titled help should be banned ! Twisted Evil
mj1704
PostPosted: Fri Apr 26, 2013 3:07 am Up
thanks macca and addaz,as for mrbsi there's always oneon every forum site.....HELP IS WHAT I REQUIRE HELP IS WHAT I ASKED FOR.MANY THANKS
mj1704
PostPosted: Thu May 09, 2013 4:14 pm Up
replaced water temp sensor now all is fine thank you...
PostPosted: Thu May 09, 2013 4:30 pm Up
Damn, this guy is fast! Smile
