Posted: Thu Apr 25, 2013 11:17 am |
new to site and i have checked this out but cannot find the answer, got a 1999 1.1 pug all was well but heater wouldn't get very hot so i changed thomosat heater then worked well no overheating but ever since has started to rev on its own ok when cold ok when warmed up but always in the middle is when it starts cleaned out throttle no air leaks any help would be great thanks
Posted: Thu Apr 25, 2013 12:14 pm |
come on someone must have an answer even with the spelling errors,
Posted: Thu Apr 25, 2013 12:27 pm |
back to google then thought you lot might help?
Posted: Thu Apr 25, 2013 12:35 pm |
Mate, most are at work and youve posted three times within an hour, calm down
Did you bleed the cooling system?
| Team Impossible Possible
Posted: Thu Apr 25, 2013 12:36 pm |
Posted: Thu Apr 25, 2013 2:01 pm |
Putting help as the thread title = NFI.
Threads titled help should be banned !
Posted: Fri Apr 26, 2013 3:07 am |
thanks macca and addaz,as for mrbsi there's always oneon every forum site.....HELP IS WHAT I REQUIRE HELP IS WHAT I ASKED FOR.MANY THANKS
Posted: Thu May 09, 2013 4:14 pm |
replaced water temp sensor now all is fine thank you...
Posted: Thu May 09, 2013 4:30 pm |
Damn, this guy is fast!
