Latest: airmastertapes
Overall: 17133
Online Now [559]:
Visitors: 558
Today: 109973
Total: 106821787
Forums › The Car › 206 Talk › a question about speedo dials
motormania007
PostPosted: Thu Apr 25, 2013 5:38 am Up
Guys, I would like to know if the white dials in a 206 hdi would be the same as dials from a 206 xsi?
As I am loooking to simply take out the dials from my xsi and put in white dials from a hdi, I wanted to check before I did this to make sure they would be the same or is there something I need to check.
Cheers guys
sparky777
PostPosted: Thu Apr 25, 2013 9:15 am Up
Something like these may be more suitible and possibly cheaper ?
www.ebay.co.uk/itm/SAL...257994a2ed
Sparky
Zack
PostPosted: Thu Apr 25, 2013 9:33 am Up
Is the xsi A diesel to?
PostPosted: Thu Apr 25, 2013 11:28 am Up
rev counter will look a bit silly with the different rev ranges.
206gt160
PostPosted: Thu Apr 25, 2013 2:38 pm Up
I agree! the rev range will only go up to about 5000rpm (ish) on a diesel rev counter..
