Online Now [98]:
Visitors: 97
Today: 16594
Total: 138873194
Forums › The Car › 206 Talk › Can I run car with out ICV??
206gt160
PostPosted: Thu Apr 25, 2013 2:31 pm Up
If I fit a choke and also an idle setting screw and I'm doing away with my air con etc do I really need an idle control valve?
I've converted a 180 throttle body to mechanical to fit the 180 inlet on my 138 and want to know if I can just leave the sensor plugged in but just don't run it.
Any advise will be greatly appreciated as its the last part of the conversion Smile
206gt160
PostPosted: Thu Apr 25, 2013 3:33 pm Up
Anyone know anything?
1999 206 Gt... Gti180 inlet, Gti180 exhaust manifold, Gti180 injectors, Gti-6 throttle body, Custom Adapter pipe to mate the throttle body to intake, Gti180 alternator, Gti-6 ICV, Straight through stainless exhaust system, cat cams (apparently), Avo coilovers, short shift gear stick, stripped out with fixed back bucket seat and harness, flocked dash, momo steering wheel and D2 solid boss, real carbon cold air intake, Gti-6 front calipers and 288mm disks, rear drilled and grooved disks, morette headlights, sp bonnet grill 71,456 miles
2008 Audi A3 2.0 Tdi 170
Lecktorious
PostPosted: Thu Apr 25, 2013 3:43 pm Up
Trade Rating: +59
It's hardly been an hour. Give it some time.
'98 Nile Blue 306 GTi 6
It should be ok. All it does is control the air going into the engine at idle. The revs might drop too far if you turn the steering or switch the air con on at idle but otherwise it should be ok.
As long as it will actually idle it should be ok.
PostPosted: Thu Apr 25, 2013 4:20 pm Up
It will be a pig to drive, horrible fuel economy and just not worth it. Just run one
206gt160
PostPosted: Fri Apr 26, 2013 12:12 am Up
right I will give it a go and set the revs slightly higher than they would be usually and do a bit of trial and error .. and if it runs badly I'll get a block made up to accommodate the icv.. bcheers
PostPosted: Fri Apr 26, 2013 2:02 am Up
Not sure what you mean by adding a choke though. Don't see how you'd do that.
I would have just started off with a throttle body that would take all your standard controls/sensors.
