Online Now [814]:
Visitors: 813
Today: 70246
Total: 145549312
Forums › The Car › 206 Talk › Couple of questions
Couple of questions
Forum Index › 206 Talk
TomRobbo94
PostPosted: Fri Apr 26, 2013 10:30 am Up
Hi peoples Smile right basically I'm 18 have no mechanical knowledge but I can follow instructions easily Wink If you could number your answers so then I don't get confused (easily done) and if you only know one thing...just number it and whack the answer in Smile
1) My steering wheels had a bit of wear so whats the best way to sort it? Get a new one or is there a way of spraying it?
[img]http://i1281.photobucket.com/albums/a515/Tom_Jack-Rhys_Robinson/Feel%20The%20Fever/SteeringWheel_zps6ca5668a.jpg?t=1366989325~original[/img]
2) How do you take out the ashtray? I don't smoke or intend too plus I wanna make a dock (like the one on here) but for android Wink
[img]http://i1281.photobucket.com/albums/a515/Tom_Jack-Rhys_Robinson/Feel%20The%20Fever/AshTray_zps03a0085c.jpg?t=1366989329~original[/img]
3) don't know why but I actually like these seats.....I know strange but I don't like the headrests, can you get cloth "whole" ones not "hole" ones Razz
[img]http://i1281.photobucket.com/albums/a515/Tom_Jack-Rhys_Robinson/Feel%20The%20Fever/HeadRest_zpsc25755c9.jpg?t=1366989333~original[/img]
4) My boot trim was like this when I bought it Sad How do you take it off?
[img]http://i1281.photobucket.com/albums/a515/Tom_Jack-Rhys_Robinson/Feel%20The%20Fever/BootStrip_zps33af7e5b.jpg?t=1366989337~original[/img]
5) Finally I have a Sp alloy cap and wanna paint it.. Can you take the actual alloy bit off? If so how?
[img]http://i1281.photobucket.com/albums/a515/Tom_Jack-Rhys_Robinson/Feel%20The%20Fever/FuelCap_zps4f73863e.jpg?t=1366989342~original[/img]
Cheers Fellas Wink
Peugeot 206 1.1 Smile Best car in the world... so far Wink
Tolkienfan001
PostPosted: Fri Apr 26, 2013 10:41 am Up
Trade Rating: +13
1. Try getting one from a scrapped / breaking car
2. Pull it out
5. Sand it well, paint prep wipes, metal primer, metal paint
2005 1.4 16v Sport
Check out my 206 here!
TomRobbo94
PostPosted: Fri Apr 26, 2013 10:52 am Up
yh thought that about the wheel
is it as simple as that :/
can you not take the actual alloy cover off?
BTW Loving the car looked at the thread at what people were saying Wink doing mine black and red haha
20Drift
PostPosted: Fri Apr 26, 2013 11:10 am Up
2. Yes it is as simples as that
5. I don't think you can - you can get whole ones in blue and green (from the LX/GLX models). You can get bucket seats from a GTi interior, but that's about as close as you'll get I think
PostPosted: Fri Apr 26, 2013 11:27 am Up
4 Take the inside tailgate trim off (just pull), and unbolt it from inside the tailgate
5 Take the fuel cap off with the key and then just twist the trim off while holding onto the part that locks into the filler neck. You can either paint it, or get a painted cap and put it on, it just twist back on.
When you post photos up, use the IMG code and not the direct link. The pictures will appear on the post and means we don't have to copy and paste and go backwards and forwards to see what you're talking about
Tolkienfan001
PostPosted: Fri Apr 26, 2013 11:41 am Up
Trade Rating: +13
I've seen a couple of silver 206 including a CC with black and red since doing mine. Smile
2005 1.4 16v Sport
Paddy1795
PostPosted: Fri Apr 26, 2013 11:54 am Up
2. The ashtray just pulls out, just get a grip of it from the back and it'll pull out easy enough.
3. My car has whole headrest as standard, its a 206 1.1 look multiplexed.
PostPosted: Fri Apr 26, 2013 2:35 pm Up
Cheers Fellas Wink
Well first of all the none of the pics worked Sad
1) try to look for one in the for sale section in here,if no luck ,then try ebay,you will find some OEM leather ones.
2)The ashtray,is easy job,just press on it from behind,where there is like a slot.
3)and you can change the headrests for sure with a whole one instead of hole one,check the for sale section,or a close scrappy.
4)don't know what you mean,as i can't see a pic Sad
5) if you wanna have the alloy part without the lock mecha.,then you need to take it off,but turning it counter clock wise.
