Latest: Beduff1977
Overall: 17134
Online Now [191]:
Visitors: 190
Today: 24971
Total: 107130450
Forums › The Car › 206 Talk › 25MM Spacer
25MM Spacer
Zack
PostPosted: Mon Apr 29, 2013 12:04 pm Up
I need a a 25MM bolt on spacer that will bolt on to my gti. center bore on the car if im correct is 65.1MM then need the other end where my wheel adapter will bolt on to be 63.3MM or smaller.
Here is a picture of the adapter.
Cheers
Uz
PostPosted: Mon Apr 29, 2013 12:38 pm Up
Stick a 5mm shim in there on the wheel side and you'll be fine.
Zack
PostPosted: Mon Apr 29, 2013 12:59 pm Up
Yea but i need to run 25MM plus the one in the picture. Not 25MM in total.
A the min its like this.
But the plan is to get shot on the first 20MM bolt on spacer and 5MM spacer and get one 25MM that is 65.1MM bore to a 63.3MM Bore.
Cheers
Zack
PostPosted: Mon Apr 29, 2013 1:00 pm Up
O and its adapter not adapder lol
Uz
PostPosted: Mon Apr 29, 2013 1:07 pm Up
Is that 2 spacers and a shim..? WHAT THE f*** IS ALL THAT ABOUT..? Do you realise how dangerous that is..?
Zack
PostPosted: Mon Apr 29, 2013 1:14 pm Up
hub centric spacers are not dangerous how it is a the min it is.
MrZiggerz
PostPosted: Mon Apr 29, 2013 1:35 pm Up
Don't brake too hard Rolling On The Floor Laughing
Zack
PostPosted: Mon Apr 29, 2013 1:40 pm Up
Whys that?
PostPosted: Mon Apr 29, 2013 2:09 pm Up
More spacers mean the suspension is softer too.
Zack
PostPosted: Mon Apr 29, 2013 2:11 pm Up
Really never new that.
The fronts are just running adapters and a 5MM shim.
Really need some 25MM hub centric spacer.
Cheers
ARRAN
PostPosted: Mon Apr 29, 2013 2:30 pm Up
What's wrong with an adaptor in the width you require..? :/
See my project here.
Zack
PostPosted: Mon Apr 29, 2013 2:32 pm Up
Don't worry found what I'm looking for Smile thanks everyone
