Latest: tbafonso
Overall: 17130
Online Now [45]:
Visitors: 44
Today: 57882
Total: 104247501
Forums › The Car › 206 Problems › 1.4HDI rattle
1.4HDI rattle
Clifford
PostPosted: Wed May 01, 2013 3:18 pm Up
Hi all,
I have a rattle coming from the belt end of the engine near the bottom. Sounds loud through the wheel arch. Only rattles when idling and goes when you rev the engine above 1500.
Any one else had this?
Thanks in advance
Clive
206 1.4hdi LX 3DR
broadblaster
PostPosted: Wed May 01, 2013 3:45 pm Up
have you checked the bottom pulley mate thay are prone to going iirc they designed a new version.
on a back road playing
Clifford
PostPosted: Thu May 02, 2013 1:51 am Up
Hi,
Thanks for the reply, no not checked anything yet just tried to find the source of the noise.
How do you check the pulley, get hold of it and give it a good wiggle? Is this the pulley on the bottom of the crank?
206 1.4hdi LX 3DR
broadblaster
PostPosted: Thu May 02, 2013 2:04 am Up
yeah thats the one mate i had one go on my works 1.4 hdi van sounded like the main bearing were about to give up.
skard
PostPosted: Thu May 02, 2013 12:40 pm Up
i had a rattle on my 1.4 hdi and it was the alternator pulley, noise went once some gas was applied to get the revs up
xdoddyx
PostPosted: Thu May 02, 2013 3:49 pm Up
Will be the bottom pulley, if its the original they have a rubber middle which wears down and fails..
Moonstone HDI
sicskate
PostPosted: Fri May 03, 2013 9:04 am Up
Trade Rating: +13
Do you have to remove the cam belt to swap these?
307 1.4hdi Smile
skard
PostPosted: Fri May 03, 2013 9:52 am Up
no, auxiliary belt
DREWDEN
PostPosted: Mon May 06, 2013 5:01 am Up
I had these symptoms on mine, mechanics were saying pulleys, was advised to change auxillary belt first and see how it went, changing just the belt everything is now hunky dory even a year later.
206 2ltr Hdi glx 53 plate
