Posted: Wed May 01, 2013 3:18 pm |
Hi all,
I have a rattle coming from the belt end of the engine near the bottom. Sounds loud through the wheel arch. Only rattles when idling and goes when you rev the engine above 1500.
Any one else had this?
Thanks in advance
Clive
Posted: Wed May 01, 2013 3:45 pm |
have you checked the bottom pulley mate thay are prone to going iirc they designed a new version.
Posted: Thu May 02, 2013 1:51 am |
Hi,
Thanks for the reply, no not checked anything yet just tried to find the source of the noise.
How do you check the pulley, get hold of it and give it a good wiggle? Is this the pulley on the bottom of the crank?
Posted: Thu May 02, 2013 2:04 am |
yeah thats the one mate i had one go on my works 1.4 hdi van sounded like the main bearing were about to give up.
Posted: Thu May 02, 2013 12:40 pm |
i had a rattle on my 1.4 hdi and it was the alternator pulley, noise went once some gas was applied to get the revs up
| Former owner of a 1.4 HDi for six years | |
Posted: Thu May 02, 2013 3:49 pm |
Will be the bottom pulley, if its the original they have a rubber middle which wears down and fails..
Posted: Fri May 03, 2013 9:04 am |
Trade Rating: +13
Do you have to remove the cam belt to swap these?
Posted: Fri May 03, 2013 9:52 am |
sicskate wrote: |
Do you have to remove the cam belt to swap these? |
no, auxiliary belt
Posted: Mon May 06, 2013 5:01 am |
I had these symptoms on mine, mechanics were saying pulleys, was advised to change auxillary belt first and see how it went, changing just the belt everything is now hunky dory even a year later.
| 206 2ltr Hdi glx 53 plate | |
