Latest: tebas93089
Overall: 17179
Online Now [96]:
Visitors: 94
Bots: 2
Today: 37404
Total: 138345533
Forums › The Car › 206 Problems › Interior door lock pins pop out of GTI door cards on 1.1
dannyhimo
PostPosted: Fri May 03, 2013 3:46 pm Up
Just put a GTI interior in my 1.1, the front door cards are slightly different, they are flat along the window line whereas the old ones were sloped. Now when the doors are unlocked the pins pop out over the door card which means that when I lock the car the pins don't always go down and the car wont lock, is there a way anyone knows of to get bigger door pins? or remove the current ones, cut the wire down a bit and refit them? any help would be much appreciated
Uz
PostPosted: Fri May 03, 2013 3:52 pm Up
Easiest way to do it is to just bend the metal work around that hooks the pin to the locking mechanism so it's sitting lower down.
dannyhimo
PostPosted: Fri May 03, 2013 9:08 pm Up
cheers, will try that tomorrow!
dannyhimo
PostPosted: Sat May 04, 2013 5:32 pm Up
sorted it cheers!
