Latest: cogeim7
Overall: 17185
Online Now [842]:
Visitors: 841
Today: 37202
Total: 147557847
Forums › The Car › 206 Problems › Brake Pedal travel Compensator Adjustment?
206-GTi
PostPosted: Sun May 05, 2013 4:08 am Up
Hi all,
Since I have had the GTi, the brake Pedal travel seems really excessive.
It seems about 40mm of pedal travel before the pads start to grip the disc. Towards the end of last year I had the master cylinder changed to rule out the possibility of something escaping.
I've searched the forums but always seem to get a million unrelated results even down to a single search term.
Is there such a thing as a brake pedal compensator on the GTi? If so where can I find it and how does one get the best out of it?
Any help appreciated.
GTi - Black - 2002
PostPosted: Sun May 05, 2013 6:40 am Up
Nope, its controlled by the abs by the EBD system.
Leegsi
PostPosted: Sun May 05, 2013 9:00 am Up
Pretty sure the master cylinder has a threaded rod that you can lengthen to take up any play.
206-GTi
PostPosted: Sun May 05, 2013 12:37 pm Up
Where abouts do you think this would this be? within the servo?
Cheers
GTi - Black - 2002
PostPosted: Sun May 05, 2013 12:50 pm Up
Best not dicked about with unless you KNOW what you are doing!
206-GTi
PostPosted: Tue May 07, 2013 8:52 am Up
Would a gti180 master cylinder be of any benifit do you think?
Assume if the rod is adjusted on the MC there's a possibility of not being able to brake as hard?
Cheers
GTi - Black - 2002
