Latest: jackrox1992
Overall: 17186
Online Now [643]:
Visitors: 642
Today: 3757
Total: 148391449
Forums › The Car › 206 Talk › Lexia P2000 on ebay?
Forum Index › 206 Talk
Leegsi
PostPosted: Sun May 05, 2013 4:21 pm Up
Is this a good pric and how easy is it to use: www.ebay.co.uk/itm/LEX...2a2c683ad7
I use Op-Com for Vauxhalls but not used this.
Are there guides or info what it can do etc,
PostPosted: Sun May 05, 2013 4:41 pm Up
It's about average for a clone.
With the cloned set up, you take a chance performing any task. It's easy enough to use if you can follow on screen instructions.
You should be able to (de)activate functions in the BSI, pair new remote fobs, code virgin immobiliser chips, find airbag faults, bleed ABS brakes, basically anything that the dealer can do. The only thing I wouldn't attempt is a BSI update.
PostPosted: Sun May 05, 2013 4:44 pm Up
Price is very good but bear in mind clone (china) interfaces are not 100% like the real thing.
They can cause problems sometimes depending what you try to do with them, so exercise great care..
Also, the software supplied is often messed-with code, not a clone disk from Planet office / Lexia, which in my view is the worst part.
Finaly, it won't do ECU/BSI firmware update due to needing access to PSA server.
Other than that, it's an absolutely brilliant tool which for that money there is no discussion.
