Latest: tebas93089
Overall: 17179
Online Now [116]:
Visitors: 115
Today: 14183
Total: 138161245
Forums › The Car › 206 Problems › rev counter flicking gear stick shaking
gloves93
PostPosted: Wed May 08, 2013 2:40 pm Up
I was driving my 206 earlier, and for about half an hour the car was driving sound. Then the rev counter needle kept flickering up and down and the gear stick was shaking then if I applied any pressure on the accelerator the car would cut out. It would then take a couple of mins to start again. Also the battery and oil light flash when the needle flickers.
Has anyone had this problem and if so what was the solution.
I\'m new here, thought i\'d join as i\'ve just bought my first car, 206 1.1 zest 3 black (55)
Tolkienfan001
PostPosted: Wed May 08, 2013 2:47 pm Up
Trade Rating: +13
Could be a loose connection maybe the earth? Or battery? What condition is the battery in?
2005 1.4 16v Sport
Check out my 206 here!
gloves93
PostPosted: Wed May 08, 2013 2:49 pm Up
The battery is in quite good condition but the positive feed female end from the car is quite corroded
Tolkienfan001
PostPosted: Wed May 08, 2013 2:53 pm Up
Trade Rating: +13
Tbh I have little knowledge on this issue. I am sure some of the guys will have a better idea. But the corroded terminal sounds like a good place to start...
2005 1.4 16v Sport
gloves93
PostPosted: Wed May 08, 2013 3:18 pm Up
Cheers mate I'll try that the most annoying thing is that I finally passed my test today and I paid 1500 to insure it and this goes wrong :/
gloves93
PostPosted: Thu May 09, 2013 5:14 am Up
i took her into the garage this morning and the machanic couldnt find the fault, he said to just keep driving it and to phone him if it does it again :/. he said that its probably because the car hasnt been driven in so long
harvey
PostPosted: Thu May 09, 2013 6:28 am Up
this happend to me once and i even took the key out and it still didnt stop untill i put it in to gear and clunked it out the best thing to do is fiddle with the speedo cable there's a little clip on there that some time gets stuck try putting some lube on there from stopping it sticking it solved my problem
harv
