Posted: Wed May 08, 2013 1:30 pm |
Posted: Wed May 08, 2013 1:37 pm |
even if they did dont expect any difference
Posted: Wed May 08, 2013 1:44 pm |
What you mean? they will make my ride harder wont they?
Posted: Wed May 08, 2013 2:08 pm |
Why not just go buy a proper set of bilstine dampers designed for the 206?
Posted: Wed May 08, 2013 2:28 pm |
are they adjustable do you have a link?
Cheers
Posted: Wed May 08, 2013 4:07 pm |
they might slightly but the torsion bars set how stiff it is
Posted: Wed May 08, 2013 4:10 pm |
To make it stiff you need stiff dampers found some now any way 110 delivered me gaz ones
Posted: Wed May 08, 2013 7:34 pm |
Zack wrote: |
To make it stiff you need stiff dampers found some now any way 110 delivered me gaz ones  |
LOL
Posted: Thu May 09, 2013 1:22 am |
Uz wrote: |
Zack wrote: |
LOL |
What
Posted: Thu May 09, 2013 1:54 am |
Zack wrote: |
Uz wrote: |
Zack wrote: |
LOL |
What |
So, let me get this straight... if I had a 1.1 with 17mm torsion bars and stuck just a set of SPAX bone breaking shocks on the rear end, my suspension will be stiff..? No itll still flop around like a limp d**k.
To stiffen suspension you have to do spring and shocks / torsion bars and shocks not one or the other.
Posted: Thu May 09, 2013 2:02 am |
What the point in adjustable dampers then? If they don't do anything.
Posted: Thu May 09, 2013 2:17 am |
Zack wrote: |
What the point in adjustable dampers then? If they don't do anything. |
Try and learn what a shock absorber does first, and then you might start understanding the workings of the suspension system.
Posted: Thu May 09, 2013 2:38 am |
Well i have ordered them now so ill just fit them
Posted: Thu May 09, 2013 2:54 am |
Posted: Thu May 09, 2013 2:59 am |
Fit uprated dampers to a car with standard torsion bars. Put 100kg in it. The suspension drop will be the same as before.
Put the same load on a car with uprated torsion bars and it won't drop as far.
The clue to what dampers do is in their name. They dampen the energy in the torsion bars. So they slow down the suspension movement.
