Latest: jackrox1992
Overall: 17186
Online Now [1065]:
Visitors: 1064
Today: 268980
Total: 147964608
Forums › The Car › 206 Problems › engine light still coming on!!
joep206
PostPosted: Thu May 09, 2013 12:03 pm Up
Had my 51 plate 1.1 for a year now and for the past 6 months I've had the engine light come on. It goes off when you turn the engine off and on but comes back on after a few miles. Had the injectors changed and new coils but it's still coming on! Any ideas what the problem might be??
Cheers
PostPosted: Thu May 09, 2013 12:08 pm Up
What fault code has come up when you plugged a code reader in?
joep206
PostPosted: Thu May 09, 2013 12:16 pm Up
P0202. Number 2 injector but i know it isn't that because it has been replaced twice now.
PostPosted: Thu May 09, 2013 12:26 pm Up
You do know number 1 injector is at the GEARBOX end of the engine on a Peugeot / Citroen?
joep206
PostPosted: Thu May 09, 2013 12:35 pm Up
All the garages that I've had it in have said its the number 2 injector but look at me with a confused look on their face when i tell them its already been replaced twice. Just want to know if anybody has got any suggestions
PostPosted: Thu May 09, 2013 12:39 pm Up
Has the correct injector actually been replaced?
Cylinder number 2 would be the 3rd cylinder from the left when standing at the front of the car looking towards the engine.
Has anybody checked the wiring harness circuit for injector 2 isn't faulty?
joep206
PostPosted: Thu May 09, 2013 12:43 pm Up
The correct injector has been replaced but i don't thing the wiring too it has. Do you reckon that is what the real fault is?
PostPosted: Thu May 09, 2013 12:50 pm Up
Swap injector two with four, see if the fault swaps.
PostPosted: Thu May 09, 2013 2:55 pm Up
Did they replace with the right coilpack too?
And definately replaced injector 2 and not 3?
Harness / connector could be causing it, as said above.
PostPosted: Thu May 09, 2013 2:58 pm Up
If its non plexed you could always just take the bulb out the cluster Laughing
