Latest: Beduff1977
Overall: 17134
Online Now [1094]:
Visitors: 1093
Today: 113899
Total: 106974371
Forums › The Car › 206 Talk › Rear Dampers
Rear Dampers
Go to page Previous  1, 2
Zack
PostPosted: Thu May 09, 2013 3:04 am Up
Edward wrote:
Fit uprated dampers to a car with standard torsion bars. Put 100kg in it. The suspension drop will be the same as before.
Put the same load on a car with uprated torsion bars and it won't drop as far.
The clue to what dampers do is in their name. They dampen the energy in the torsion bars. So they slow down the suspension movement.
Thank you for explaining Smile
Is it both i need like on this link? if so what size?
peugeot-tuning-parts.c...-bars.html
Cheers
PostPosted: Thu May 09, 2013 11:57 am Up
But gas dampers 'push-out' a bit whereas plain oil ones don't.
So it will have the effect of stiffening a bit together with the tightness of the damper itself no?
Those tires are way out there though, is this photoshoped or..?
Zack
PostPosted: Thu May 09, 2013 12:08 pm Up
That's what I thought but maybe not ill see when fitted.
Nah it's real
PostPosted: Thu May 09, 2013 12:59 pm Up
Under no load they might push out but with the weight of the car on them they won't push the car higher at all.
Zack
PostPosted: Sat May 11, 2013 1:09 pm Up
Fitted gaz rear dampers today and the ride is stiff as hell.
19Connor92
PostPosted: Sat Jun 01, 2013 5:17 am Up
is that on the Avo ones your trying to sell as brand new?
Zack
PostPosted: Sat Jun 01, 2013 5:19 am Up
Yea ordered to sets lol one avo one gaz and can't return them try cost me 176 pound and I want 80 for them
PostPosted: Sat Jun 01, 2013 7:02 am Up
Is that good?
Zack
PostPosted: Sat Jun 01, 2013 7:04 am Up
Well yea that's what I was after Smile
PostPosted: Sat Jun 01, 2013 11:26 am Up
OK.
Page 2 of 2
