Latest: S2cgm
Overall: 17178
Online Now [292]:
Visitors: 291
Today: 76458
Total: 137002611
Forums › The Car › 206 Problems › VIDEO UPLOADED 10/05/14 - Oil light low revs issue continues
Tolkienfan001
PostPosted: Thu May 16, 2013 4:21 am Up
Trade Rating: +13
V9977 wrote:
What is a foot open beep?
Checked the brake fluid level?
Done any work on the brakes recently?
Do you have ABS?
Lol door open beep.
I do have ABS. New pads and discs on the front. Brake fluid on max.
As this only happens under braking, just before I come to a stop. I am starting to think it is an ABS issue. I have not had a car with ABS so what am I looking for?
2005 1.4 16v Sport
Check out my 206 here!
PostPosted: Thu May 16, 2013 4:23 am Up
macca1411 wrote:
Predictive text or very small keyboard?
I'll hazard a guess it should be door.
If it's door open sound, maybe there is an interminent contact on one of the locks. It will only take a millisecond to trigger the sound even though there's not enough time to display the message on the MFD or flash the interior light etc. That's just a crap guess though.
Have you bled the system with PP2000 to switch the ABS block to bleed?
Is your ABS dash-lamp working OK?
Tolkienfan001
PostPosted: Thu May 16, 2013 4:52 am Up
Trade Rating: +13
Is your ABS dash-light working OK?
I think the light is working. It comes on when I start the car with the other lights. Then goes off.
I do have an issue with the drivers lock. I struggle to lock / unlock with the key. Also have a knocking sound inside the door. Just not got round to sorting it yet.
If it is a door issue where is the sensor and what should I be looking for?
2005 1.4 16v Sport
PostPosted: Thu May 16, 2013 4:56 am Up
The sensor (switch) is inside the lock/latch unit itself with the locking motor etc.
The barrel is sepparate though if that has gonne stiff.
When did you do the brakes/disks?
Did you do bleeding with PP2000 for the ABS?
PostPosted: Thu May 16, 2013 5:12 am Up
Could do with this thread merging with your other one as they seem related
www.206info.co.uk/Foru...54713.html
PostPosted: Thu May 16, 2013 5:14 am Up
Big_Rich180 wrote:
It probably isnt this but I used to get a single beep on start up when my ABS was shagged.
PostPosted: Thu May 16, 2013 5:27 am Up
Also, do you have a bonnet switch and a tailgate switch fitted?
Tolkienfan001
PostPosted: Thu May 16, 2013 5:40 am Up
Trade Rating: +13
I don't have pp2000. And did not bleed the brakes.
However this issue was happening before the brakes were changed.
2005 1.4 16v Sport
PostPosted: Thu May 16, 2013 5:41 am Up
I would bleed the brakes too if it was me.
Tolkienfan001
PostPosted: Thu May 16, 2013 5:43 am Up
Trade Rating: +13
How do I test this?
2005 1.4 16v Sport
PostPosted: Thu May 16, 2013 5:45 am Up
Tolkienfan001 wrote:
How do I test this?
In the tailgate striker there will be a switch with two wires going into it.
For the bonnet, the easiest I think is to open the bonnet with engine running and see if you get a beep and MFD message.
Tolkienfan001
PostPosted: Thu May 16, 2013 5:54 am Up
Trade Rating: +13
Ok I will test this later. If I have both of these I take it your thinking is the switches maybe faulty?
2005 1.4 16v Sport
PostPosted: Thu May 16, 2013 5:55 am Up
Just another thing to check.
And as macca says clean the ABS sensors and rings.
Tolkienfan001
PostPosted: Thu May 16, 2013 6:00 am Up
Trade Rating: +13
Need to get pp2000 then. Can't afford that till August. Are the sensors and rings on both front and back? I have drums on the back.
2005 1.4 16v Sport
Tolkienfan001
PostPosted: Thu May 16, 2013 6:10 am Up
Trade Rating: +13
Is brake cleaner ok for the rings and sensors? Wire brush or cloth?
Thanks for all the help and advice guys!
2005 1.4 16v Sport
Page 3 of 6
