Online Now [630]:
Visitors: 629
Today: 190837
Total: 146893307
Forums › The Car › 206 Problems › engine turning but not fireing
Andy_Boo
PostPosted: Fri May 17, 2013 3:52 pm Up
hi all could anybody tell or show me where the fuel line comes into the engine I need to check if fuels getting there thank you for the replies in advance
PostPosted: Fri May 17, 2013 4:06 pm Up
Which engine?
Are you sure it's not the immobiliser preventimg the spark?
J206PUG
PostPosted: Fri May 17, 2013 4:11 pm Up
Join the club Sad
What did I miss ???
Andy_Boo
PostPosted: Fri May 17, 2013 4:16 pm Up
its a 1.1 petrol. and it sounds like lack of fuel everything else works lights windscreen wipers hazards surely if it was on none of the above would work?
PostPosted: Fri May 17, 2013 5:11 pm Up
Is it priming?
PostPosted: Sat May 18, 2013 4:55 am Up
The immobiliser prevents the spark being sent to the sparkplugs from the ECU and possibly cuts off the fuel pump (MrBSI?). It's not an electrical isolation device.
A common fault on a pre-plex is the aerial in the steering column going faulty and needing to be replaced.
Have you had any work done to the car recently or made any modifications just before it stopped running?
Have you tried the spare key?
Like Steve says, can you hear the pump priming when you turn the ignition on?
Andy_Boo
PostPosted: Sat May 18, 2013 1:53 pm Up
today after checking everything mechanically I decided to start with the dreaded electrics (which I don't really like) and found the crank sensor to be faulty ordered a new 1 for £17.50 cheers for the fast responses
Andy_Boo
PostPosted: Thu Jun 06, 2013 2:39 pm Up
the cars still not running ive replaced the the sensor ive got eco mod on the dash and the engine management light on
PostPosted: Thu Jun 06, 2013 2:58 pm Up
Get it recovered to your local Peugeot main dealer.
Why do I get the feeling we only have half the story
Have you been dicking around with the electrical system?
