Online Now [129]:
Visitors: 129
Today: 11357
Total: 138633326
Forums › The Car › 206 Problems › 3 bulb or 4 bulb clock that is the question
topdog226
PostPosted: Sat May 18, 2013 1:50 am Up
Hi all first post so take it easy on me I have a 206 GTI SP and the clock/radio desplay went I tried to open it up have a general nose around when I pulled the ribbon out now heres the thing the clock in there is a 4 bulb but would a three bulb clock work cause as far as I can see they are the same apart from the number of bulbs???
tsotd
PostPosted: Sat May 18, 2013 4:28 am Up
in a word no, 4 bulb is the ppt-30 for the pre-plex and the 3 bulb is the ppt-40 and is muti-plex.
its a common problem for the display to play up on the ppt-30, you can DIY fit it, there is a guild somewhere on this forum
Topaz 2.0 16v 205 Gti6 (ph1.5)
Mercury 2.0 16v 206 Gti (ph1)
topdog226
PostPosted: Sat May 18, 2013 7:00 am Up
Thanks for that info ill try and find the guide
PostPosted: Sat May 18, 2013 6:06 pm Up
Yes, it's called the 206info ppt Guild.
