Online Now [343]:
Visitors: 342
Today: 40472
Total: 106017574
Forums › The Car › 206 Problems › Brand new comm2000 unit, brand new problems
idnan
PostPosted: Sun May 19, 2013 1:05 pm Up
Hi guys,
having a few issues with my 2002 multiplex 206 2.0 HDi. The car was bought with an airbag fault. By scanning the fault codes for the airbag it seems the comm2000 unit was at fault. I bought a brand new comm2000 unit from Peugeot and it is exactly the same as the one I removed. The battery went flat a long while ago so I proceeded to remove it and change over the comm unit. The car also had an issue with the indicator stalk as well.
The airbag light has gone out but now the wipers are on all the time on the slowest setting and occasionally the washer motor comes on and squirts the screen.
The car has been jumped started, could a weak battery cause this issue? I tried a BSI reset but to no avail. The other stalk works perfectly now.
Any ideas?
Tolkienfan001
PostPosted: Sun May 19, 2013 1:14 pm Up
Trade Rating: +13
Try soft booting the BSI.
BSI Soft Boot
2005 1.4 16v Sport
Check out my 206 here!
idnan
PostPosted: Sun May 19, 2013 1:18 pm Up
Thanks for the tip. It appears it was due to the battery. I left it hooked up to the other car for 15 minutes and tried again and all seems to be fine.
I'll buy a new battery for piece of mind.
Tolkienfan001
PostPosted: Sun May 19, 2013 1:20 pm Up
Trade Rating: +13
Most garages can test the battery for you, before you buy a new one...
2005 1.4 16v Sport
frenchfrog40
PostPosted: Sun May 19, 2013 5:29 pm Up
mine says it has an airbag fault and if my wipers are in the off position they randomly wipe. i have to leave it in auto wipe so when you turn the car off and on it thinks the wipers are off. dam comm unit. how much was it bought and fitted?
Iv had:
Tolkienfan001
PostPosted: Mon May 20, 2013 12:56 am Up
Trade Rating: +13
There is a guide on here on how to fit it. It is easy to follow. I had to replace my comms last year. I got it from ECP for just over £100. They had a discount code for 30% off at the time.
2005 1.4 16v Sport
