Latest: S2cgm
Overall: 17178
Online Now [302]:
Visitors: 300
Bots: 2
Today: 78843
Total: 137004982
Forums › The Car › 206 Problems › running on 3 cylinders
Sk3rry93
PostPosted: Sun May 26, 2013 12:51 pm Up
So serviced my 1.1 206 and a few hours later she started running on 3 cylinders, local auto factors gave me the wrong spark plugs so quickly replaced them with bosch super 4's that I'd used before and a few hours later she developed and began running on 3 cylinders, I've tested the injectors and coilpack and the plugs are fine any ideas as to what's wrong?
Cheers in advance Smile
PostPosted: Sun May 26, 2013 1:13 pm Up
faulty coil pack maybe
Sk3rry93
PostPosted: Sun May 26, 2013 6:00 pm Up
Tried a differnt coilpack and the problem is still there, had the codes read and it showed nothing
Deckchair5
PostPosted: Mon May 27, 2013 1:07 am Up
Reset the engine base data by disconnecting the battery for a few hours and let it relearn the best settings. Always a good idea to do that whenever changing major engine running affecting components but particularly if you put the wrong plugs in as the base data for fuel trims and ignition timing will be all over the place
What were the make and type of the original plugs?
Are Bosch super 4s actually compatible with your 1.1 engine?
Spark plugs
As a test, put the old plugs back in, if it runs sweet again then there's your problem
