Online Now [56]:
Visitors: 55
Today: 45839
Total: 116919610
Forums › The Car › 206 Talk › well what do you think?
Go to page Previous  1, 2
motormania007
PostPosted: Thu May 30, 2013 10:50 am Up
Thanks all for your opinions, I will deffo consider the lowering of the rear but I need to get a mechanic to look at the rear end as I changed from the 17" vortex wheels in the hope it would allow me to take rear passengers and the rear wheels would sit nicely under the rear arches, but it dosen't so I have got a feeling there must be a problem with either the rear torsion or the rear shocks cause when have rear passengers it still catches the arches and the tyres are 195/55/15 same size as original steelies so something must be wrong.
I know I should have got it checked out before swapping, bit late now thou.
Cheers pete
206gti_chris
PostPosted: Thu May 30, 2013 11:15 am Up
as the mirror backplate has been colour coded, it would make sense to pull of the B pillar vinyl off
motormania007
PostPosted: Thu May 30, 2013 11:23 am Up
I am confused with what you mean by b pillar vinyl? If you can explain I would appreciate it
Cheers
kizza93
PostPosted: Thu May 30, 2013 11:56 am Up
He means the black strip that runs verticaly next to the window
PostPosted: Thu May 30, 2013 2:33 pm Up
The wheels and bumpers never go together. The colour coding is OTT too. Headlights aren't good either. Just looks like every accessory has been fitted to it.
Page 2 of 2
